Adding PV to my first Victron SCC 150 / 45 -- Please check my calculations
Dinobot248
OHIO
I’m trying to add some solar panels to my new Victron Smart Charge Controller 150 / 45 and connect it to my existing 48v off grid system (EG4 6500EX, 6 Lifepower4 batteries and 10k PV (yes its over paneled but still under max VOC). With my current setup and shade / trees, on an excellent winter day, I get 8kwh and a bad day I may get 0.5 kwh. My best summer day was around 20kwh.
Long term, I will eventually acquire and switch out to Victron. Right now I want to make sure that I am properly understanding how many PV panels I can connect to the Victron SCC 150 / 45.
I have 170w TopSolar PV
VOC = 24.26 V
VMP = 20.41 V
ISC = 8.83 A
IMP = 8.33 A
In the Victron manual, it has
Max PV open circuit (VOC) = 150 V
Max short circuit (ISC) = 50A
Nominal power = 2600 W
To be safe, I wanted to start off with 4 parallel sets of 5 panels in series. I prefer sets of 6 since my DIY ground mount holds 12 panels. For now, I will use 5 for calculations.
5 x 24.26voc = 125v. This is well under the max VOC of 150 V
Theoretical max operating current 4 x 8.33 = 34 A. This is under the 50 A
Theoretical max power 20 x 170w = 34000w.
This is above the max 2600w. For my area, actual best winter rate is 0.8 solar hour and summer rate is 2 solar hours for the entire day. I am not as concerned and I think the SCC will limit the power if there is a miracle that I can come close to getting 75% of my rated PV power.
Questions / Comments
  • Please check my work and provide feedback.
  • Can I use 6 panels (VOC = 146 V = 6 x 24.26 V) and still be safe and under the max 150 VOC limit? I know there are some variances. In winter time, one of my PV array is 12 panels (12 x 24.26 = 291 voc) in series and per Solar Assistant, has been less than 250v for the past 21 winter days.
Link to Manual
Thanks in advance
You need to adjust for coldest temperatures recorded in your area your 5s is the most you can safely do 6s is definitely a no go
doing rough calculations 5s in very cold weather might hit 151.625 volts depending on your specific panel temperature adjustment numbers
