Jack Rabbit Off Grid
- Sep 6, 2021
- 478
Technically you have a generator. It’s not very efficient but would work in a pinch since you run a 12v system. Jumper cables and a Dodge.
Back in the day when I built my very first system in a 1973 Dodge class C. I used a 8d battery I got for free out of a friends boat. Mounted some real cheap solar panels on the roof and some cheap controller. I found my self in the same spot. The panels couldn’t keep up. Being I was a Diesel technician at the time. I replaced the factory Dodge alternator with a 160 amp one out of a KW T600 tractor. Couldn’t afford any fancy generator back then. In the morning if the battery was dead just fire up the gas guzzler 440 and let it idle. I even had the for thought to over drive the alternator so it would put out full power at idle.
