My AIMS SCC60-100A has three connections at bottom in addition to the Network and Battery Temp Sensor:
In many videos I have watched, the Inverter is wired to a 4-way BUS Bar that the solar charge controller and battery bank also connect to.
So, as mentioned in the opening, the SCC has Solar, Battery and DC Load connections. The 'DC Load' connection rated at up to 60amps DC.
My question: Is this SCC DC Load connection intended to wire to the Inverter INSTEAD of connecting the inverter to the 4-way BUS bar? Is it intended instead for a secondary DC Load source such as a converter to power 12volt systems in the House? Sadly, the AIMS Installation/Operator manual provides no info beyond 'connect DC load +/-...'. While considering this, I realized that I may need to draw A LOT more than 60amps into the Inverter. I am using a 200amp in-line fuse between Inverter and the 4-way Bus Bar. At this time, it is my assumption the DC Load connection is intended for use with a 60amp DC converter to power 12volt DC systems.
- Solar Pv +/-
- Battery +/-
- DC Load +/-
