jameshowison
- Jul 30, 2021
- 185
Could someone point me in the right direction?
I'd like to find a way to tell a DC load to shut down based on state of charge of the batteries. Use case is to ensure that the fridge is always powered (until the very last smidge of DC power in the batteries). We will have a DC HVAC system that may use plenty of power but should always be turned off if things run low.
System is victron, including a Cerbo GX and a smart shunt. I figure this is something about relays, with something watching either voltage or shunt state of charge and triggering a relay that turns off a switch on the relevant circuit? Hmmm, that seems like a pain as that essentially requires a networked disconnect.
Perhaps this is something I can do with a Victron battery protect on the HVAC circuit, shutting that down if voltage drops to a particular level?
Any suggestions for other disconnects that can be triggered by relays? Amperage is low (like 40amps), 48v nominal system.
