wow 50% is huge. I'm in the Philippines, fairly close to the equator. Currently I just have about 250w of solar panels that I made myself from damaged cells, EVA, and glass. Do you think I"d see that kind of improvement if I came up with a tracking mechanism? Where are you at?Here's a pic of my trackable system, from the back, so you can see the construction. I call it "Hillbilly solar tracking" because I walk out and rotate the panels left and right by hand. It works. I find I can increase my total power by about 50% over the course of the day. ...
This is why I went with manual positioning. I tell myself, KISS. In the morning, the arrays only need 2-3 minutes of attention to get them angled just right. Avoiding shading is to top priority. What I find though is that by 9am the sun is now far enough south that I don't need to worry about shading, but I still angle the panels maybe twice before noon, and twice after.I ended up cutting them all up with a plasma cutter about 2 years in when the linear actuator failed for the 2nd or 3rd time and the control box cooked for the 5th time. I was so close to using a plc to automate a tracker of my own, when I finally came across a deal for 24 solar panels for $1200 and ended up making a much larger ground mount array. I set it up so that one array of panels faced east and the other array faced west, and I now have a much higher capacity to make up for the loss of the tracker.
The goal here is just keeping the pump running all day long.
That is a LOT of pumping. Can you share a little info and a pic if its interesting?I typically see about 18-20kwh of production per day.
That is the ONLY thing that kept me from buying property out in the country. But, I did see in KY they wired an entire rural county with high speed. So it does exist somewhere.The only modern ammenity we don't have yet is high-speed internet. I'll get to it!
Nice, seeing that is cool. Are each of them single panels or are there many on each pole. Its difficult to tell the scale of them.Here's a pic of my trackable system, from the back, so you can see the construction. I call it "Hillbilly solar tracking" because I walk out and rotate the panels left and right by hand. It works. I find I can increase my total power by about 50% over the course of the day. The frame holding the panels has door hinges welded to a horizontal unistrut welded on top of a 4" schedule 40 steel pipe. The 4"pipe sits on top of a 3.5" pipe sunk in concrete. the horizontal struts at the bottom allow me to make seasonal angle adjustments. My primary goal is running my wellpump, which requires about 2200W, and rotating the arrays allows me to pump from 8:30am to 4:30 pm instead of 10:30 till 2:30. In the early morning and the late afternoon, I fiddle with the panels so they won't shade each other, but after about 9:30 they only need to be moved 2 or three times.
Looks like 3 horizontal panels each pole.Are each of them single panels or are there many on each pole
The smaller arrays hold three 72-cell panels, 900W per array. The larger array holds four 60-cell panels for a total of 1000W. Using larger steel members and multiple unistruts in parallel, I've drafted a design that could hold six of those. That array is still in the conceptual phase.Nice, seeing that is cool. Are each of them single panels or are there many on each pole. Its difficult to tell the scale of them.
Do you have any good links for cheap DIY manual positioning systems? My current situation has me kind of limited on real-estate for placing panels (the house isn't mine ... yet), so it'd be great if I could maximize with positioning. I'm home very often so I can easily walk out every few hours and move something around. I know how to weld (ugilly), thank you youtube, so it's fine if the DIY includes that.This is why I went with manual positioning. I tell myself, KISS. In the morning, the arrays only need 2-3 minutes of attention to get them angled just right. Avoiding shading is to top priority. What I find though is that by 9am the sun is now far enough south that I don't need to worry about shading, but I still angle the panels maybe twice before noon, and twice after.
The goal here is just keeping the pump running all day long. Around 3:30 or so I need to worry about shading again. By 4:30pm, I have to shut off the wellpump, because I can't maintain 2000+ watts. By 5:00, shading gets bad enough that I start getting more power by facing the panels due south again. Although the pump is no longer running, I can still get 500-1000 watts out of the system to keep the batteries topped off before sunset. I typically see about 18-20kwh of production per day. With regular night-time loads like lights and TV, I'm still at 90% charge the next morning.
I am upgrading with more panels in the next few weeks. These are going to be positioned in a totally different area on the other side of the cabin, and are designed to be facing due west. The goal is to get enough watts to run the wellpump till after 6pm (or an air conditioner). I found some fantastic deals for panels on Craigslist (1kw for 220$), so I'm throwing more watts at the problem, 1000W at a time. What I'm finding now is the the steel to build the panel frames is costing more than the panels!
The inexpensive trackers I've seen are flimsy jokes in my mind! Yes, my welds are pathetic too; that's why all my pics are from 30 feet away!Do you have any good links for cheap DIY manual positioning systems? My current situation has me kind of limited on real-estate for placing panels (the house isn't mine ... yet), so it'd be great if I could maximize with positioning. I'm home very often so I can easily walk out every few hours and move something around. I know how to weld (ugilly), thank you youtube, so it's fine if the DIY includes that.
solar trckers are dirt cheap compared with the cost and effort of mounting more panels.IMHO, It depends on what's wrong with them, how much it'll cost to fix and maintain. Might be good, might be bad.
I'm totally serious, can you send me some links? I had written them off as either too expensive or unreliable.solar trckers are dirt cheap compared with the cost and effort of mounting more panels.
For my DIY trackers, I'm finding that I'm spending twice as much money on the steel to make the frames, then I am the panels. I'm still utilizing tracking arrays not so much so because I want maximal production, but maximal production at a certain time of day. If I want to start my wellpump at 7:30am, I MUST have tracking. That being said, since I also make my stationary frames out of the same steel, the cost difference is just a few hundred$.solar trckers are dirt cheap compared with the cost and effort of mounting more panels.
Hey, have you ever tried mirrors? I've been contemplating making a "mirror sun tracker" since they are much lighter (though it may be manual at first). Have the mirrors follow the sun and redirect extra light to the panels (even if panels are already tracking)?For my DIY trackers, I'm finding that I'm spending twice as much money on the steel to make the frames, then I am the panels. I'm still utilizing tracking arrays not so much so because I want maximal production, but maximal production at a certain time of day. If I want to start my wellpump at 7:30am, I MUST have tracking. That being said, since I also make my stationary frames out of the same steel, the cost difference is just a few hundred$.
Just a short few years ago, I know a guy on Craigslist that was selling 10' unistruts for 5$ each. Just bought what I needed at the time. Now, as I get a little array crazy, I wish I had bought a truckload. But I didn't, so now I pay retail at Home Depot. If I still had access to that steel, you'd see some really fancy designs.
Well, give it a try and get back to us about the results.Hey, have you ever tried mirrors? I've been contemplating making a "mirror sun tracker"
it'll be a couple of months. Waiting for lockdown to end here then I'm upgrading to a real off-grid system. I did experiment with mirrors on my home-made panels, and they absolutely boosted power output. I was able to get well over cell rated capacity; I don't remember how much 20% feels right.Well, give it a try and get back to us about the results.
