interesting. i dont know that i can exactly exclude items from the solar setup. i have my main meter about 100ft from my house and my house is essentially on a 200amp subpanel. I'll check into the wattages of everything a bit more before i buy. there is also a 12kw and a 15kw for $800 more or so. i'm not dead set on fronius either, someone just said they were best, do you have a recommendation?
I have seen Fronius in commercial set ups in my area, and they are well regarded here, but I don't have one. The specs look very impressive to me, and I looked up the costs for a pair of 11.4's (bit rich, but I am considering it due to the high PV voltages these support).
There are a couple ways you can go, with the main panel and solar:
You can back-feed into an existing panel and reduce the power that is supplied from the grid, but these "grid tied zero export" systems seem (from what I know) to always suffer from some back feeding, and modern smart meters will pick this up, and result in issues contact from the utility. I was tempted in my own system to do a 'grid-tied-zero-export but then thought about big loads that will suddenley shut off, and result in some export currents, which my smart meter will no-doubt report and I would be in hot water with the (Provincially owned) utility - so I didn't do this route.
The other option - is put a new panel beside your existing one, for solar supplied loads, and move over the circuits that you want on solar. Leave on the utility any that your system may not be able to support - say the hot tub for example - and pay the bill each month for just that, while most of your home runs off the solar. The utility can still supply the AC input side of the inverter, for charging batteries during a cloudy December for example, and this will not back feed to the grid ever.
The other option is what is called a Critical Loads Panel -CLP- which allows either utility or other source (generator or solar) to be the power supply for critical loads like furnace fan, well pump, lights, fridge freezer - and the CLP has separate switches so you can pick and choose at any time which loads are supplied from utility or from your solar. Look up the Reliance 306 as an example - I used this one - and see how this is designed to sit between your utility panel and another power source, originally these were designed to work with a generator, but work the same way with a solar set up. I find the CLP especially handy during low solar time of year, as it lets me easily choose to put some loads back to the utility, that would normally run on solar most of the year in my set up. I didn't look to see if there is a Reliance large enough for a hot tub, but likely there is, and this may be a good option for your set up, so you can with the flip of a switch move this load from utility to solar or back if required.
To be clear about my own set up: I have two dedicated electrical panels for solar loads 'all the time' and I also have the 30 amp Reliance for a few key items (furnace fan, well pump, fridges, freezers and lights in kitchen & bathroom) so I have options for those key items at any time with the Reliance switches. Is this right for you? not sure, but something to consider.
