I have 2x 6500ex in split phase, wired with a common neutral, screws removed from the factory. They've been running flawlessly since March. I RMA'd one of the inverters after i found an issue with one of it's MPPT controllers, and received a new inverter from SS. I installed the new one 2 weeks ago, but it was running on old firmware, so i went ahead and upgraded it to the latest 79.71 firmware with the bonding setting 42, and upgraded my other inverter to the same firmware. I set the setting 42 to "enabled" and tested the common neutral on both inverters for continuity to verify and then switched my CL panel over. The inverters ran fine for 2 weeks, then 2 days ago, I noticed they were stuck in bypass even though i had 100% SOC, and the LED screen was dimmed even though i never disabled that setting. I checked the settings and they were reset! Setting 42 was "disabled", the LED backlight was disabled, setting 12 was set to 100% which is why it was stuck in bypass mode, and my 2p2 inverter's setting 05 was "AGM" mode instead of "USE"! Thank god it was in bypass mode or else it could have fried circuits in my house and maybe even caused a fire!
I've fallen back to the previous, 79.70 stationary firmware, with which I had 0 issues with. Luckily, I had that saved because EG4 downloads page doesn't have links for older firmware.
Lessons learned:
If any future firmware upgrades will have option 42, I'll jumper the AC in neutral to AC out neutral to be safe.
Lessons learned:
- Don't be a guinea pig for latest EG4 firmware.
- Save the firmware downloads so you can fall back if needed.
- Verify continuity between neutrals and ensure there's no NG bond after all firmware upgrades going forward.
