Battery build #3 gets commissioned tomorrow!
Skypower
Solar Wizard
Dual module(so I can move the beast) compressed (squeeze box). This one will be on a rolling bace and enclosed with a differential thermostat controled cooling fan. Air is only circulated if the air is cooler than the cells and if needed. The voltage and current will slowly increase and the JK bms will slowly balance the first time to full. Single compression spring in each module. After glue and dowel assembly, the wood was treated with fire retardant and painted with 2000 degree header paint. Thermal fuse shuts off fan and bms.
