Falcon Structures 10 foot shipping container, BUILT OUT!
10ft One Trip Container Type CX03-210 with Corten steel construction
8' wide x 10' long x 8'-6" tall nominal dimensions Tare weight: approx. 3,000 lbs
CSC Safety Approval USA/AB-596/10 effective through 3/2024
Climate Control: PTAC A/C Unit, 230/208V, 15k BTU with 2kW electric heat
42"W x 16"H x 14"D and remote programmable thermostat
Basic electrical includes an exterior 125 Amp capacity panel
60A disconnect breaker feeding a 125 Amp capacity interior panel
20A/220V outlet and a 110V duplex outlet for basic appliances with a dedicated breaker
Interior lighting with one 4ft. LED fixtures, one exterior light fixture
One interior GFI receptacle, data pass-thru provision
Three inches of closed cell insulating spray foam with R-value 20.7 on both ceiling and walls
One inch of closed cell insulating spray foam with R-value 6.9 under 80 square-feet of flooring
1-1/8" thick wood cargo flooring
Painted 1/4" wood paneling framed using 2x3 wood studs
Cargo Doors at the end of the Container
Lockbox fabricated from 3/16" steel, painted and welded to container
Purchased from Falcon in July 22, 2022 for $19,863.59
Never used, Mint Condition!
Built out for Solar Battery / Inverter storage (project cancelled)
Asking $15,000. Make a bid!
$300 delivery within 100 miles of Austin, Texas
