I think Ped's number is a worst case scenario (as they explain in their follow up). SCClockDr's seems more realistic in practice.
Based on the info at 1:25 of the video: If your Trojans are AGMs I think the equivalent BBs is
14. If they are flooded, BB equivalent is
12.
Here's how I arrived at those numbers:
From the vid: "Factoring in Coulombic Efficiency: A 100ah Lithium = 220ah AGM = 250-290ah Flooded Lead Acid"
So, normalizing your 6V lead acids to 12V (as SCClockDr does above), you have: 370 X 8 = 2,960 Ah.
- If AGM: 2,960/220 = 13.45 100Ah BBs (so 14)
- If Flooded: 2,960/250 = 11.84 100Ah BBs (so 12).
And you get 3,000-5,000 cycles at 100% capacity from the BBs.
It's worth watching the entire video to understand the total cost of ownership of LiFePO4 vs. Lead Acid. Will's coverage of the topic is comprehensive.
