I can see you're skeptical to which I say GREAT.
Deeply skeptical, and I don't mean to be rude, Its just that your numbers are drastically lower than what the manufacturers reports, what energy star reports, and what I have seen others dorm fridge owners report. Even among dorm fridge owners making the same argument as you (the efficiency gains don't justify the added cost when you could put that money towards panels/battery) I haven't come across anyone claiming a dorm fridge actually consumes less than a chest fridge, or claiming they only consume 1/3 of what energy star test data shows.
Could you link to the fridge you own?
By subtracting the idle current from the total current with fridge running.
Idle draw, and conversion efficiency are separate factors are they not?
All reports show the same across all models. It would be more prudent for you to post results of dorm fridges showing something different. I have literally never had anyone find a drastically different result.
I haven't come across such a comparison, dorm fridges are cheap consumer products plugged into walls, as such there isn't much testing to be found, All I've found is energy star testing, and anecdotal experiences like yours that vary wildly (yours being the absolute lowest claim I've heard for any type or size of fridge).
If you know of any comparison tests, please share them, I would be curious to see a true comparison under standardized test conditions.
Except the solar market was turned upside down in the past decade. Its now utterly irrational given the price per watt to even try to worry about 1-5% efficiencies, if any at all, and then pay a differential that now equals 400% solar production differences.
First, I want to say that for many situations I agree with you here. If you are not space constrained, saving money on the fridge and adding more panels and battery capacity, is a sensible route to take.
But remember you are in the vehicle subforum. Space is often the primary bottleneck in this context. Maybe it doesn't matter in your case, but for many vehicle and marine builds efficiency is very important. Especially considering that in many builds, the fridge is by far the largest power consumer, and often their is only roof space for a couple hundred watts of PV. A 20% power savings could mean an extra day of autonomy. Ignoring space constraints in the mobile forum ignores the fundamental design challenge of vehicle builds.
Fridge consumption has many variables. For instance these measurements likely assume a typical 72f inner room. In a van or camper it can be quite a bit lower.
Yes sometimes colder, just as often hotter (or more often). Especially in a mobile/solar application, where a heat source is much more likely than air conditioning. Either way, 72f is a reasonable baseline for testing and most of the testing I've seen for chest style fridges has been conducted between 68-85, so the ambient temp is relatively comparable and if anything favors consumer energy star tested fridges.
Energy ratings are generally max draw and real world measurements often lower on most if not all appliances. My TV and computer are the same.
I'm not sure how much you know about energy star testing but you can't logically say energy star tests fridges at 72f and simultaneously say they test at max draw (which they don't--they approximate real world usage). A fridge's duty cycle is determined (mostly) by ambient temperature relative to thermostat, there is no way even the shittiest fridges would be anywhere near 100% duty cycle at 72f. And unlike with your TV and computer (where an assumption has to be made in how many hours per day they will be used, and how they will be used), a fridge's consumption will be based mostly on environmental variables not usage patterns--much easier to measure consistently and predictably.
Thats pretty common knowledge in case you didnt know.
Setting aside the fact that I don't actually think this is common knowledge, you just got through chastising people for accepting common knowledge/conventional wisdom. It seems strange to rely on it here.
Why actual real world energy audits are much more valuble.
Agreed. If they are conducted properly, and reported accurately and honestly real world comparisons are valuable, if you have come across any real world tests comparing dorm fridges with chest style DC fridges let me know, I would be very curious to see a direct comparison
As skeptical as I am of accuracy of the numbers you observed, I would like you to be right, A $60 dollar fridge sipping 8-9 Wh / hr, sounds amazing in comparison to a $350-1200 chest fridge consuming 15-30 Wh /hr, or a dorm fridge consuming 25-40 Wh / hr. And I would be happy to save a few hundred dollars when I get around to buying a fridge.
