Correct. All inverters on the market have a hard time displaying accurate values, especially when at or near 0 load.Right now my inverter says solar production is 39 W. It was running full speed withoutout grid. It seems as though the inverter numbers are way off
That's awful. Thank you for update. Will remember thisI purchased an Ip6048 in Dec of 22, to run my well
Due to some issues I didn't get it installed until Dec of this year. It ran for 2 weeks and failed no voltage out error code f32, shop solar, that's who I bought it from sent the main board for me.to replace it. Replaced the board and it right up and ran for 2 weeks and failed again. After working with them via email since March, I am sending it back to them to repair. Confidence that they will be able to resolve this is very low. Any recommendations for a quality inverter? Only loads are a 220v well pump and a 110v pump to pump to the house from the storage tank.
How long is the warranty? Several SGP advertise 3 year warranty. Think you have some left if 3 year?My sgp ip6048 just died.
Purchased in Dec 2022 finally deployed Dec 2023.
Ran most of the house from batteries and solar.
About a month ago screen went dark, but inverter was working, charging batteries and running loads. All from just solar with grid breaker off.
Then something happened (maybe overload) amd it turned off. Was able to restart.
Yesterday similar thing happened:
car was charging about 1.25kw (5a)
Microwave about 1.5kw
Cooktop - god knows.
Lights and computers about 750w
So likely an overload.
But doesn't start anymore.
I can restart, enable AC out, can measure 240v.
But as soon as there is load it clicks off.
I have a second unit, bought 2 for redundancy.
Probably should have enabled parallel, was going to, but just didn't get around to it.
Now the second unit is running ok, with full fans for no reason.
But I'm kind of stuck, other models will not parallel with this. And PV is built with 600Voc.
Most inverters have 500Voc limit.
EG4 18kw hybrid looks good, but close to $5k
Sounds to me like a setting for max charging current could need adjusted.I have found an odd quirk with this particular unit.
There seems to be a limit to how much solar power it can send to the load. If the load goes about something like 4800 watts then it'll limit whatever amount of solar power is coming in to about 1600 watts and draw the rest from the battery.
Not sure if this is a bug with the firmware or some kind of hardware limitation.
It well maybe under warranty, but how would you know? (they are not to be found on the site anymore, and the manual doesn't say)How long is the warranty? Several SGP advertise 3 year warranty. Think you have some left if 3 year?
I think ppl are over loading inverters and killing them. Manufacturers should probably reduce the advertised loads but think it is a marketing thing so not going to happen. Electric air compressors use to claim 5hp 120volt 20 amp breaker. The only way they were broke from false advertising was a law suit.
Most gas generators are really only rated at 1/2 output. The instructions often tell ppl that. Most get raggy on upper end - dirty power and dependability drops if run at higher rating plus they get hotter and fuel consumption goes way up. Ppl buy undersize generators and have same problems. Then they cuss the generator when it is the advertising marketing ppl at fault.
I think we are maybe seeing some of that with these inverters and maybe for longevity the loads should be significantly reduced. Despite the advertising. I would have had them in parallel if it were me if you wanted more. We all want more. The problem then becomes we will add more load.
I would contact SGP and inquire about warranty - look at your paper work.
