I have a Daly BMS 200A. I know the B- goes to the negative terminal of the battery, but not sure where the P- goes. Do I connect it to my negative bus bar? That would supply a negative to all the loads...
There is a terminal in the middle, which I assume is what is called the C-. I'm going to install a DC-DC 20A charger -- Does the C- from the BMS go to the Negative of the DC-DC charger?
