As I have planned and assembled my 4.8Kw battery bank, BMS amperage capacity and price has become a concern.
When I bought my first BMS, I bought one rated at 100amp, continuos, 50amp charging. When it arrived, I found the gauge of the cables suspect and am concerned that trying to push 100amps (24v BMS) continuous may be a problem. I have since decided to keep this BMS as a backup and opted for two, 320amp BMS (Ant BMS) for a total cost of about $200 for the two BMS.
My battery pack uses 16, 3.2v, 100ah CALB lifepo4 cells. Two, 4-cell packs are connected in series to generate 24volts. When my other 8 cells arrive, I will have all 16. I will connect the 8 in two packs to make 24v. Then, I will connect the two pairs in parallel to have a 24v, 200ah bank. I am using two BMS wired; both as 8S BMS.
During my research of BMS products on eBay and Amazon, I have also looked at the requirements to manage raw 200, 280, 300 and 400ah cells in 24v packs. Since I have found the BMS capacity a limiting factor, I am concerned at the availability and cost of a BMS to handle, say, a 24v, 600ah bank consisting of 16, 300ah, 3.2v cells. This would be three times the capacity of my bank or roughly 4.8*3=14.4Kw. That is a large setup capacity-wise but the footprint is about double the footprint of my 16-cell, 100ah bank.
What BMS options are available to manage the larger needs for continuous amps (600) and charging amps (150)? I suspect the BMS price rockets upward for the larger cells. Hopefully, the price comes down when I am ready to upgrade (several years).
