Buchanan Splice Caps and other novel splicing methods.
hwy17
Anti-Solar Enthusiast
Santa Cruz, California
My PV run needs some splices and there's nothing I can do about it. It needs PV wire to THHN splices, and I'd rather not keep dancing around making more splices in the THHN run. There should not be a need to be nervous about a splice of under 30 amps.
1. Wagos - I trust them for AC splices of 15, 20, 30 amps. Why shouldn't I trust them for a PV splice? Only logical reason would be that a PV splice is expected to be heavily loaded. But heavily loaded at 16 amps only.
2. Wire nuts. I hate wire nutting stranded wire, I won't do it.
3. Buchanan Splices? So apparently these are a listed 600v splice method. Home Depot carries the crimps themselves but not the caps, I'm guessing because they are commonly used for irreversible ground wire splices. But they are listed for live wires with a hard to find insulator cap.
4. Anyone got any other idea for listed wire splice methods that you'd be twice as confident in as a wire nut or wago?
I've been using "Ideal" set-screw wire nuts. a.k.a. Marrettes
Oh never seen those before. Seems like the model 11 is 600v rated (model 10 300v). I don't love the presumably brass fitting as much as the Buchanan copper, but non permanent is a plus.
Hard to find like the Buchanan but half the price, about $1 each.
Gardner Bender 20-123 or 75-126
butt splices are 600v rated. But it would feel so wrong to see in a box.
They are expensive, if you have alot of connections it probably doesn't make sense.
Available as cheap as $10 a piece. I didn't expect that. Compared to spending $120 on a kit to start making Buchanan splices, maybe hard to argue against this. Probably hard to stuff these in a 1 or 2 gang box though.
It is brass, but current path should be wire to wire.
Sold by Home Depot, but not a stocked item in the store.
I've been buying on eBay.
Model 10 cheaper
Model 11 more expensive
Is MC4 an option?
Well I could professionalize my THHN to PV transition a bit with a combiner box or something that handles this a different way than an insulated splice stuffed in a box, but then in the intermediate sections I'd still be trying to avoid them. My panel to charge controller run is 250 ft with 3 different sections. So that would mean I couldn't even get two contiguous runs done with my 500ft spools of thhn that I already used 16ft of short scraps from.
I'm more interested in overcoming the limitation here, a reliable and compact 20 amp splice should not be out of reach. I'd like to be able to splice anywhere I want and not worry about it.
Panduit Stronghold seems to be their line of UL Listed butt splices.
Under 50 cents a piece, maybe a technically perfectly legal wiring method.
@timselectric Can I put butt splices in outdoor above ground weatherproof boxes for PV voltage DC or would that be too dorky?
Buchanans might beat butts in that they're a little more compact, and you get to see the inside of the crimp before you put the insulator on.
On the other hand, Buchanan's don't have as much crimp to wire surface and are relying on a wire to wire current flow. While butt splices can have a nice flattened wire contact.
Agreed and I would believe in that for splicing two clean straight solid wires. But for 12 awg stranded, my mind just imagines the set screw twisting them up or a couple hairs ending up straddling the screw instead of compressed by it.
Is the screw wider than the barrel of the connector so they can't end up either side of it?
How about waterproof heat-shrink marine butt splices? Regular ones might technically work, but high voltage DC outside wouldn’t sit right with me.
I haven't looked thoroughly, but I believe those are not usually both 600v rated and UL listed/rated. In my case these are for inside a weatherproof box like this with a gasket sealed cover plate:
