Hi all,
I have my (2) 335 Watt Solar Panels mounted on the side of my garage. I used a Cutting Edge Power Entry Housing (https://www.amazon.com/gp/product/B07MMWKR29/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1) to bring the wires in through the garage wall. Inside the garage, I used a simple plastic junction box to connect the wires from the Entry Housing assembly to a 10/2 Romex wire running to my MPP Solar AIO.
For the last 6 months, I had the panels wired in series with no issues. Last week, I changed the panels to be wired in parallel (to gain more power into the MPP unit. This change successfully got me about 100 additional watts from the panels.... For about an hour, before things went up in smoke (see attached).
I guess, it could have been a coincidence with the change in panel orientation. But, it seems like the increased amperage got things too hot. But, here's what has me stumped...
The Entry Housing is supposedly rated for 30 amps. According to my Solar Assistant, I was only seeing about 15 amps from the panels at the time of the incident. (The panels can't produce much more than that anyway). From the looks of the aftermath, it looks like the issue started at the Wago Connectors (which are also rated for 30 amps).
The only thing that I can think happened is that I had put ferrules (https://www.amazon.com/gp/product/B08J7M8X49/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&th=1) on the 10awg wires from the entry housing and maybe the ferrules didn't make a good connection inside the Wagos?
I'm going to replace the junction box with a metal box now. But, I'm nervous about whether I can still use the entry housing and remaining unburnt wire and whether I can still use Wago's (or just twist with a wire nut)? Either way, I think I'll leave out the ferrules.
Thoughts?
Thoughts?
