Scoutmaster
- Jul 20, 2022
- 90
Thanks ?
I’ll have to experiment. I’ve been running the generator to charge my battery.
I’m in the mountains so it’s going to be difficult to keep them snow free.
I need to mount them vertical to keep the snow off.
I was just surprised that only 20watts of power was coming in mid-day.
I definitely overestimated how many watts I could pull from just 4x100w I anticipated at least 100w for 3-4 hours hoping it would keep my battery happy.
I actually think the solar controller and blue tooth dongle might actually be using more energy than the 400w of solar can create in the winter.
You're lucky to get anything with indirect sun.I only get 2-3 hours of indirect sun.
4 ParallelYou're lucky to get anything with indirect sun.
What SCC do you have and how are your panels arranged? All parallel? 4S? 2S2P?
4 in Parallel.
I think it’s all set up correctly.There are array options that would raise your voltage if that is part of your issues. Your pic shows only 13.2V from solar. You NEED to get this up to at least 5V above battery voltage (where most SCCs start charging). Putting your panels in series will help if your SCC will accept the increased voltage (see your SCCs max input voltage, temp adjusted on Voc).
But it sounds like you need to get direct sun whether its by moving your panels or tilting them.
Need more info to provide more (some?) help.
Its in your pic...It does say 13.2V for the solar?
I have 4-100w panels on parallel.
Parallel universe: https://diysolarforum.com/threads/when-the-sun-migrates-for-the-winter.50802/4x 100w panels at my cabin only producing about 20-30 watts this winter
I harvested 2 kWh yesterday from my 4 KW array here in Colorado. Worst day of the year!! :D One more week until SOLSTICE!!Parallel universe: https://diysolarforum.com/threads/when-the-sun-migrates-for-the-winter.50802/
35 watts is what I’m doing this overcast day in Vermont or of a normal ~400W
Renogy Wanderer is a PWM controller. Until you near 100% SOC it directly connects the panel array to the battery. When you do that panel voltage drops to match the battery charging voltage. In your case that's 13.2V, perfectly normal for LiFePO4. If you unplug the panels from the SCC and test the open circuit voltage directly it will be much higher, maybe 25V with your weather.I wonder if the SCC is damaged already.
We get -15 easily and have already seen 0.
It was cheap like $40 so can buy a new one.
And they still got shadows ? LOLboom truck to set it all into place
Trees? No problem! All it took was 3' diameter pipe with a 5/8" wall, 10 yards of concrete in a 12' deep hole, and my 30 ton boom truck to set it all into place. Nothing has moved in 15 years. The lawn to the right was not an option, for legal reasons, and the customer STILL wanted solar,
so we gave it to him.
ItSo I have 4x 100w panels at my cabin only producing about 20-30 watts this winter. Is this normal? I only get 2-3 hours of indirect sun.
