Can the Lifepower EG4 24v be hooked up in series to use in a 48v system?
Dragoth
Utah
I know you can generally run LifePo4 batteries in series without issue so long as you do it right, however, I can't find any information regarding the Lifepower EG4 specifically. Does this config cause issues with the BMS and will 2 24v Lifepower batteries play nice if I add it to a system running 48v Lifepower or LL batteries?
For context, I am currently running a 24v system in my RV and want to pull the batteries in the future to use in a home that is going to be 48v. TIA!
Yes it's possible. I'm doing it now. SS seems to have put out conflicting info, some saying series pairing is supported, some saying opposite.
It works, batteries charge and discharge. With comms cables, I'm able to read status of all 4x 24v batteries using bms-test software.
