I was thinking of setting up a 24volt All-in-One system, but was wondering about isolater use. Can it be utilized with 12v to 24 volt converter or something, as they all seem 12v for van use that I've seen... as they are reading the coach battery charge levels which wouldn't match a 12v spec. So, I was wondering if the 12 volt alt flow could be sent into the All in One system like the solar or hookup... again, different voltages, unless you get the 12volt All-in-One, right? Or, you would have to get a second alternator like most of the companies put on, right? Seems they go to a much higher volt alternator Is that the only way to go? Putting in a second alternator, if you don't use a 12volt All-in-One and 12v battery setup? Staying 12v seems the only way to make use of the 12v alternator... seems a waste not to utilize it... if the skies aren't friendly for a while. Since I'm in the planning stage, it seems a good idea to think of these issues now. Any thoughts?
