SunDave
Hi all,
Anyone have experience with similar equipment that can chime in and let me know if this is normal?
I have a sol-ark 15k and 30kWh of Pytes 48100r batteries. Previously I was running my battery down to about 40%, then getting whatever sun I get, but since I have bumped up the low-end of the battery % before going to grid to get a fuller charge. I have a starter 2kW array in until I get the full 19kW array installed soon.
When I charged say from 40-55% during a day, the charge went up by about 1% every 15 mins of good sun. Basically it went up in steps, like you would imagine it would. Now when charging today from 83% and going up from there, it seems to sit around 90% for a long time. Today, in good sun with a steady 1kW+ going to the battery for over 5 hours, it barely budged the % charged. Started off going up, then sat at 90% for 4 hours.
Normal or no? Is there some kind of change in charging procedures at around 90%? If it charged that long and the battery voltage didn't change much for hours, and the battery keeps taking the full 1kW where is the power going? Just a sensor or algorithm in the Sol-Ark that is still learning the battery bank?
I have full coms on CanBus with the Pytes batteries and their BMS says the same thing. Wattage going in, but SOC and voltage not changing much over many hours.
So to anyone with a similar setup. Ideas? Normal? Not enough wattage to get past a certain point in the charge cycle (absorb?). I don't want to change settings or call support unless it is an issue. I can give it a couple days too to see if it is a consistent thing.
Thanks!
Thanks!
