Nope, busy with jobs... no time to tinker, to many people with heat out...Any results yet?
it that time of year to make $$$$Nope, busy with jobs... no time to tinker, to many people with heat out...
The discussion of using all the same length balance wires was very timely for me. I know the wire size is very large for this purpose but my assumption is it cannot hurt to go larger. Am I correct in this assumption?
Thank you for your input. I have been thinking that there just isn't enough extra wire to worry about, so why not make all the leads the same length just in case it would have an effect.I have wondered about this myself.
Voltage drop across the wires will be zero if there is no current and increase linearly with rising current. If the cells are balanced, the current will be near zero and the voltage drop across the wire will be near zero regardless of the length of the wire. The voltage drop will be the most when the BMS is trying to balance cells. By definition, ballencing is not going to run the same current to/from every cell so if there is any significant voltage drop, the drop will be different for each cell while balancing. I was convinced keeping the lengths the same would not matter, but then I noticed that on some of the bluetooth BMSs there are two wires to one of the cells. Could one be a voltage sence to that cell? If so the BMS could be measuring the resistance of the wire to that cell and then assuming the resistance is the same on all cells. This would give it the data needed to make a good approximation of the voltage at the cell even though there is a voltage drop.
I have a water level switch 80' down and used the resistance for the 160' round trip to bring the voltage to a level that the switch could handle, but that was in addition to a resistor at the surface, still it was 24 AGW and 160'. The BMS leads are in inches not feet, but still why risk possible problems over a few inches of wire. As for me I will just make the leads the same length.When designing electronic control systems you can sometimes use the resistance of the lead wires as part of required circuit resistance. I'm not saying they have here but that CAN be the reason in some circumstances. It could be a particular BMS design did that and so now the community thinks they all need the same length. (Just saying.)
is that the normal specs for the byd, 3.65?V I have read on this 3.65 is extreme only on new battery 2.5v is the extreme low,, no bms? wtf. you waste no time, wow"ITS IMPORTANT TO HAVE BALANCING IF YOU PLAN ON FULLY CHARGING AND FULLY DISCHARGING. JUST SEARCH ALIEXPRESS FOR "8S ACTIVE BALANCER". OR YOU CAN USE AN 8S BALANCE CHARGER WITH THE BALANCING FEATURE.
NOMINAL VOLTAGE IS 25.6V
FULLY CHARGED IS 29.2V
FULLY DISCHARGED IS 20V"
Charging to 56 (instead of 100% 58.4)
Returning to the utility at 44 (instead of 40) - No BMS!
(I have grid-tied solar. These inverters (LV5048sj) support 8 kW each, 4x2 solar inputs)
View attachment 3933View attachment 3934View attachment 3935
1st test!
S - U - C - C - E -S - S
Whole house on battery! YES!!!!!! 1st test.
View attachment 3936View attachment 3937
I can't figure out the software monitor yet though, I guess it only works WiFi, but I'm connected USB and nothing.
They weight a ton, I am keeping very close to the ground, on a rack too risky for me,, may jam my toe on it, smiles I will send an update on the changes.Excellent!
Thanks for those details.
I have 6 coming and was wondering what I was going to do. I think I know now!
