Sorry, I was wondering about what batteries were inside the 24v battery module.It's a 24v all-in-one inverter. mppt controller, charger.
Are you sure of the usage?Great idea! I will need something bigger that I can walk into and stuff due to the size of my family and energy usage needs (I'll need quite a few batteries) but that's a very creative solution!
I have a whole house energy monitor (Sense product) and during the winter my highest usage per day is about 155kWh. Trying to decide how to size the battery bank if I wanted to take half the house off grid. Living in the midwest, heating via heat pump is the highest consumption during winter. We are dual fuel with propane based on where we live (no natural gas opportunities) but electric is still cheaper than propane.
Any ideas on how to calculate what was need in batteries at 24V?
"BYD has an external control box for the built in BMS so that it can talk to SMA and other inverters/chargers via rs485/CAN. These BYD modules are the first gen version as far as I can tell. MFG date is gonna be around 2013 I would guess. This is for the 2.0 version https://www.cclcomponents.com/byd-b-box-battery-management-unit "
Thanks for this link, Picasso. I did a quick search beginning with this information. Confusion: all I found refers to BY 2.5 Kwh modules, not the 5.6 nominal KwH modules we are buying. Is this version 1 vs version 2? Most interesting is that Victron has linked up with BYD to provide access to the interal BMS. See: https://www.victronenergy.com/live/battery_compatibility:byd_b-box . Notice the very informative wiring diagram contained on this site for an entire BD - Victron system. Can someone with more knowledge than myself analyze this new information? Q. Can we use the Victron link with our batteries to use the installed BMS directly without having to remove it and rewire? Q. Does the wiring diagram look good for putting an entire small home system together?
I reached out to a buddy that programs backup systems for a living, I will post here if he can make up a solutionAfter a lot of searching today, I am at a dead end. I talked with a Victron technical support person and he said the Victron equipment communicates with the BYD BMU unit which communications with the BMS installed on each battery module. Picasso provided a link to a BYD BMU, unfortunately it is for the 48 v B-Box system not for our 24 v battery. A search for a BYD 24 v BMU brings up nothing. I called BYD north American division and they deal with automotive matters and had no idea what I was talking about nor could they transfer me to someone that might know. So, its a dead end as far as I can see.
... I changed my order... for 700.00 more I got 4!I got two on the way.
I will post up my plans when they get here...
Ok... now I want some 48v units...Supervstech: glad you are getting 4 units, same as what I am getting. Cant wait to start working on them with you.
I found a bit more background history. BYD introduced the B-Box series of 48 v 2.5 KwH batteries in 2017 to replace the 24 v 5.6 Kwh batteries we are buying. See: https://www.solarquotes.com.au/blog/byd-brings-b-box-battery-battleground/ . But no closer to finding any technical specifications for this battery nor any hint of a BMU.
Hi all. My first question here on the form. Very excited to develop my system. How would this work with using the MPP Solar 24V. After the BMS is installed, is there anything I would install between the BMS and MPP? This is where I'm not sure. I'm thinking a Victron Battery Protect, and a fuse on the battery or this that not necessary since the MPP has the Circuit Breakers/ Temperature Protection/ Custom Charge Profiles features.View attachment 1994
They are back in stock (3000 units available), and after looking them over and asking Tom (owner of battery hookup), a daly bms is what most people are using. I should also add, that they do not have low temp cut, so you need a victron controller w/ battery sense (with low temp cut off enabled) if you wish to use it with solar.
Because I am getting a lot of emails about this, lets throw together a battery package so that you do not damage the batteries:
Attached below are pictures from Tom showing how most people are charging (ISDT or similar chargers). This works well for most people, but if you do not have a low temp disconnect, and your batteries get cold during the winter and it charges with solar, the battery will be destroyed. But for some of you, it will work well:
- Click Here for the Batteries. And use coupon code "SOLAR" (my affiliate code) for 10% off entire order
- Click here for a 200 amp Common Port 8S Daly BMS (if you need more than 200 amps, use a 500 amp relay, and trigger it with this bms)
- Click here for victron SCC's. Be sure to add a battery sense (click here) and enable low temp protection.
- If you want check the invidual cell voltages, click here for a balance lead and click here for a cell monitor
View attachment 1990View attachment 1991
They even make a 1000w charger now: click here, but it does not have low temp cut off protection.
So yeah, pretty simple battery to use at a good price. The next thing you guy's need to know is that the shipping charges are extreme unless you order more than one battery. So it is best to order multiple batteries, or pick them up at the warehouse (1375B Adams Road Bensalem PA 19020 )
Let me know if you guys want to know more about these batteries. Pretty simple to use and require your own low temp cut off, but crazy cheap!
Hi. New here too. There are videos on Will Prowse's YouTube channel on buildlng 24v systems where he uses a 24-12V converter and Blue Sea 12V fuse to allow you to use 12V appliances with 24V system. https://www.mobile-solarpower.com/2000-watt-24v-solar-system.htmlSo I'm new here, but I have a question, these are listed at 24v, but also claim to be good you for an RV which most run 12v.
I'm not seeing anything that would make these easily changed to 12v.. or am I missing something? Because the size to price seems amazing, Especially if split to 12v and I could pick it up to save shipping....
This should do the trick unless you need more than 40 amps.So I'm new here, but I have a question, these are listed at 24v, but also claim to be good you for an RV which most run 12v.
I’m driving down from Toronto tomorrow morning to pick up two of these for my planned RV. @Will Prowse I’d asked previously about the LV2424 and inductive appliances (induction cooktop, microwaves. Any thoughts on that?Thats the beauty of it. They are lifepo4, so they will work perfectly. Unlike tesla or any NMC pack. Those are cheap, but have a horrible voltage to work with. lifepo4 works perfect with 2424lv
Just picked up two of these batteries and am down the street at the local Cracker Barrel.I’m driving down from Toronto tomorrow morning to pick up two of these for my planned RV. @Will Prowse I’d asked previously about the LV2424 and inductive appliances (induction cooktop, microwaves. Any thoughts on that?
