cs1234
Solar Wizard
- May 9, 2022
- 2,305
Click the picture. But I'll put it separate.Link?
The cells might be decent enough to just rip out and use your own bmsIf those are really screws holding the top on, you can even open it up and see how poorly it's built!
Kind of depends on what loads you run? You could use a 2 or 3k inverter and it would just die if you exceed what the single battery can do.Which 48v inverters would be happy with the discharge current limits on a 50ah?
Yeah I was sniffing at the 50Ah form factor for a while but it's kind of an outlier for 48V thus far.Kind of depends on what loads you run? You could use a 2 or 3k inverter and it would just die if you exceed what the single battery can do.
Personally, I think the size is nice, as it's cheaply shipped and easily handled.
2 of them is half the price of a reliable name brand 48v rack battery for 100ah. You get what you pay for of course.
It's nice seeing one available so cheaply though, they had been gouging bad for 48v vs 12v or 24v batteries. Maybe they are starting to come around and see we want some 48v ones at similar prices to 12v by amp hour.
The point is, it's available on Amazon with free shipping for the equivalent price of a 12v battery by amp hour. It satisfies the people that say you shouldn't run 12v batteries in series.Yeah I was sniffing at the 50Ah form factor for a while but it's kind of an outlier for 48V thus far.
I don't like thinking different. This halfsie size is certainly conveniently small, but it's weird for future proofing, as the inverter that would be specced to work with it would be pretty small and a bigger inverter has risk of tripping the BMS even if you keep the loads low. So what's the point other than saving minimal amounts of wire vs 24V given the low current in question?
The amps are low, if you don't mind the voltage drop, run wires all around the place..That's a lot of energy density in non UL9540A / UL1973 batteries stacked up in a corner of a garage.
Well you did say you were going to stack them a lot...The amps are low, if you don't mind the voltage drop, run wires all around the place..
I understand you're one of the resident safety / code experts on the site. It's helpful and appreciated for the knowledge alone, but.. people have different levels of scoff law'ing they are willing to engage in. We have a whole sub-forum here of people building their own batteries, some of them have nearly 50-100kw of custom built battery.. none of it to code. They are using better BMS's, but that hardly matters when the bomb disposal squad shows up.Well you did say you were going to stack them a lot...
The wires all over doesn't help when the bomb disposal squad comes out to deal with a battery problem.
Oh I think I trust the people that build their own batteries more than making a stack of suspiciously cheap batteries.
Although... if Amazon is willing to warehouse these batteries, it can't be that bad? ?
Oops it ships from someone else, it's not Fulfilled By Amazon.
