I have one of these things in my shop, and it actually works quite well.....save one issue.
I have a small 12V battery, Not this one but one of the same size
as well as a lead acid "lawn mower" battery. The diesel heater will work just fine off of these batteries no issue at all.
The diesel heater sits about 10' from the solar battery bank. My charge controller has a 12v out that I use for lights.
The diesel heater will not run off of the 12v out from the charge controller. As I understand things the heaters will draw 10+ amps when starting up then calm down a bit, figured perhaps it will not support that kind of output.
Wire direct into the bus bars, still no joy.
Diesel heater comes up with an error that says not enough voltage. Ok, checked voltage on the wire coming out 13+v depending naturally. Still the same error. I am thinking perhaps it is the size of the wire, 12 too small? Went to 10, same error, angry I went to 2 same error.
And yet perfect function when the battery is 1' away.
Deeply puzzled.
Any suggestions on this.
Deeply puzzled.
