conquistador
- Sep 21, 2021
- 108
Today I ran a test crimp vs solder.
I used 4mm² copper which translates to 10AWG and cheap brass lugs. The cheap crimping tool is from Aliexpress.
To measure the resistance, I feed 1A through the wire via a bench power supply, limited at 1A. Then I measure in the 200mV setting on the Multimeter. This translates to 1mV= 1miliohm, so basically the Voltmeter shows in miliohm in the 200mV setting.
Here are the results:
crimped only in the 4-6mm² slot of the tool:
1.0 and 0.8 mOhm
crimped in the 4-6mm² slot and then in the 2.5mm² slot
1.7 and 3 mOhm !!
These ones i re-crimped in the 4-6mm² slot and got
0.7 and 0.8 mOhm after recrimp
After measuring, I soldered all of them with a 100W iron and 40/60 tin, rosin flux:
the recrimped: 0.5 and 0.6 mOhm
the crimped in the 4-6mm² slot and soldered: 0.5 and 0.5 mOhm
While I acknowledge that my tool and my lugs are crap, soldering after crimping seems to improve resistance significantly.
1.0 and 0.8 mOhm
1.7 and 3 mOhm !!
