First time crimping using a 12 ton crimping tool and these types of lugs. Tested converting the 6AWG cable that comes with the EG4 batteries and M6 lugs to ones that use M10 for the bus bar I plan to use in the future. (I also plan to use larger wire gauge)
On the first attempt the lug developed "wings". On the second attempt I started with a larger crimping die to attempt to create the shape and then went to the 6AWG die. The wings happened again but slightly smaller. I rotated the lug and compressed the wings down.
The final results aren't pretty but I can't pull it out by hand as hard as I try. I tried to fix the first attempt by compressing the wings but some sharp edges developed, so I filed them down.
Questions:
Is there a proper/better way to do this?
Am I just using wrong lugs with a wrong crimping tool? (SELTREM lugs, AMZCNC 12 ton crimping tool)
Is a single crimp enough or do I need to make sure the whole thing is crimped as much as possible?
Thanks for the suggestions!
Questions:
