havesomejoe
Joe Petrakovich
- Sep 21, 2019
- 38
This is kind of complicated to explain so bare with me..
I recently installed an automatic transfer switch into my RV and connected my inverter to it so that now shore power and my inverter can power the same existing set of outlets. Something surprised me when I was testing it.
I forgot that the way the RV was designed, when you are plugged into shore power, the converter powers your DC fuse board instead of your battery.
Somehow I overlooked this "back-channel" of DC power, and because I wired my system together in a circuit that flows through the inverter's terminals, my inverter receives power from shore power (I attached a diagram) and can thusly be turned on in a way that skirts my intended fused route from the battery.
If the inverter is able to turn on, I don't think it's that big a deal because the automatic transfer switch should prioritize shore power, so the inverter wouldn't do anything.
But my fear is that in some rare scenario someone could plug a device directly into one of the inverter's spare outlets and that maybe my system isn't designed for this pathway so something would cause a fire.
If you look at the diagram there is a 50a circuit breaker that I could just disconnect to.. break that circuit... but it's rather inconvenient to remember to do that whenever I have shore power, and it's located underneath a seat that i'd have to lift up to get to.
What do you think, could this play out badly or is it sufficiently protected via fuses and breakers? I'm thinking the latter, but wanted to get a second set of eyes on it.
Looks like the diagram photo is getting compressed too much so here is a link to it in full resolution.
