tanoshimini
- Mar 28, 2021
- 110
I have a some SmartBMS units from Daly that I want to talk to. On other threads in this forum, I've seen some discussion of the protocol, and there have been some successes that people have had in getting some documentation out of them. Having read over the documentation, I've come to discover that it only covers a few aspects of the BMS, and does not cover at all, anything to do with setting or retrieving it's configuration parameters.
To that end, I decided to use a Teensy 3.2 to monitor both sides of the communication between the BMS and the official Daly BMS software as it goes about setting and retrieving various parameters. Here's a raw dump of the back and forth I captured:
Normal chatter about cell voltages, etc. This stuff is covered in the documentation, and served as a sanity check.
This stuff is more interesting... It's the sequence that runs when you mash the "Read All" button on the "Read Settings" page of the official app. Attached below is a screenshot of the app after it's decoded this sequence. The app appears to helpfully group settings into things that can be retrieved with a single command, and these groups correspond 1-to-1 with the command sequence. It shouldn't be too hard to pick apart which one does what.
Likewise, this is a dump of the sequence that from mashing the "Set All" button on the "Parameter Settings" page. It looks like they largely mirror the commands being send in the read section, and it shouldn't be too much work to prove that out.
Code:
-> a5 40 90 08 00 00 00 00 00 00 00 00 7d
<- a5 01 90 08 02 10 00 00 75 30 01 f4 ea
-> a5 40 91 08 00 00 00 00 00 00 00 00 7e
<- a5 01 91 08 0e c8 05 0e 9c 09 01 f4 c2
-> a5 40 92 08 00 00 00 00 00 00 00 00 7f
<- a5 01 92 08 3d 01 3d 01 9c 09 01 f4 56
-> a5 40 93 08 00 00 00 00 00 00 00 00 80
<- a5 01 93 08 00 01 01 10 00 00 4e 20 c1
-> a5 40 94 08 00 00 00 00 00 00 00 00 81
<- a5 01 94 08 0e 01 00 00 02 00 00 20 73
-> a5 40 95 08 00 00 00 00 00 00 00 00 82
<- a5 01 95 08 01 0e c0 0e c2 0e c7 20 d7
<- a5 01 95 08 02 0e c8 0e c8 0e c6 20 e5
<- a5 01 95 08 03 0e c2 0e c2 0e 9c 20 b0
<- a5 01 95 08 04 0e c4 0e c4 0e c4 20 dd
<- a5 01 95 08 05 0e c3 0e c0 0e c4 20 d9
-> a5 40 96 08 00 00 00 00 00 00 00 00 83
<- a5 01 96 08 01 3d 00 00 00 00 00 00 82
<- a5 01 96 08 02 00 00 00 00 00 00 00 46
-> a5 40 97 08 00 00 00 00 00 00 00 00 84
<- a5 01 97 08 00 00 00 00 00 00 00 00 45
-> a5 40 98 08 00 00 00 00 00 00 00 00 85
<- a5 01 98 08 00 00 00 00 00 00 00 00 46
-> a5 40 d8 08 00 00 00 00 00 00 00 00 c5
<- a5 01 d8 08 00 00 00 00 00 00 00 00 86
Code:
-> a5 40 50 08 00 00 00 00 00 00 00 00 3d // Query the rated pack capacity and nominal cell voltage.
<- a5 01 50 08 00 00 9c 40 00 00 0e 74 5c
-> a5 40 5f 08 00 00 00 00 00 00 00 00 4c // Query the voltage thresholds that control balancing.
<- a5 01 5f 08 0d 48 00 32 00 00 0e 74 16
-> a5 40 52 08 00 00 00 00 00 00 00 00 3f
<- a5 01 52 08 00 00 00 00 00 00 00 00 00
-> a5 40 60 08 00 00 00 00 00 00 00 00 4d // Query the short-circuit shutdown threshold and the current sampling resolution.
<- a5 01 60 08 07 d0 00 64 00 00 00 00 49
-> a5 40 51 08 00 00 00 00 00 00 00 00 3e // Query the "Number of acquisition board", "Cell counts" and "Temp Sensor counts" ???
<- a5 01 51 08 01 0e 00 00 01 00 00 00 0f
-> a5 40 53 08 00 00 00 00 00 00 00 00 40 // Query "Battery operation mode" / "Production Date" / Battery Type" and "Automatic sleep time" ???
<- a5 01 53 08 01 02 15 03 06 ff ff 00 20
-> a5 40 54 08 00 00 00 00 00 00 00 00 41 // ??? Query the "Firmware index number"
<- a5 01 54 08 32 30 32 30 30 33 30 36 8f
-> a5 40 57 08 00 00 00 00 00 00 00 00 44 // ??? Query the "Battery code"
<- a5 01 57 08 01 32 30 32 30 30 33 30 5d
<- a5 01 57 08 02 36 20 20 20 20 20 20 fd
<- a5 01 57 08 03 20 20 20 20 20 20 20 e8
<- a5 01 57 08 04 20 20 20 20 20 20 20 e9
<- a5 01 57 08 05 20 20 20 20 20 20 20 ea
-> a5 40 61 08 00 00 00 00 00 00 00 00 4e
<- a5 01 61 08 00 00 00 00 00 00 20 20 4f
-> a5 40 62 08 00 00 00 00 00 00 00 00 4f // Query Software Version
<- a5 01 62 08 01 32 30 32 31 30 32 32 6a
<- a5 01 62 08 02 32 2d 31 2e 30 31 54 85
-> a5 40 63 08 00 00 00 00 00 00 00 00 50 // Query Hardware Version
<- a5 01 63 08 01 44 4c 2d 42 4d 53 2d de
<- a5 01 63 08 02 52 33 32 2d 30 31 45 9d
-> a5 40 59 08 00 00 00 00 00 00 00 00 46 // Query the Level 1 and 2 alarm thresholds for high and low cell voltages
<- a5 01 59 08 10 36 10 04 0a f0 0b b8 1e
-> a5 40 5a 08 00 00 00 00 00 00 00 00 47 // Query the Level 1 and 2 alarm thresholds for high and low voltages for the pack as a whole
<- a5 01 5a 08 02 45 02 3e 01 88 01 b2 cb
-> a5 40 5b 08 00 00 00 00 00 00 00 00 48 // Query the Level 1 and 2 alarm thresholds for charge and discharge current for the pack.
<- a5 01 5b 08 6b d0 6f 54 7e 90 78 1e ab
-> a5 40 5e 08 00 00 00 00 00 00 00 00 4b // Query the Level 1 and 2 alarm thresholds for allowable difference in cell voltage and temperature sensor readings
<- a5 01 5e 08 01 f4 00 c8 0a 0f 78 1e 78
-> a5 40 5d 08 00 00 00 00 00 00 00 00 4a
<- a5 01 5d 08 03 e8 03 fc 00 c8 00 64 21
-> a5 40 5c 08 00 00 00 00 00 00 00 00 49
<- a5 01 5c 08 5f 69 05 00 69 6e 05 00 b3
Code:
-> a5 40 10 08 00 00 9c 40 00 00 0e 74 5b // Set the rated pack capacity and nominal cell voltage.
<- a5 01 10 08 01 10 00 00 75 30 01 f4 69
-> a5 40 1f 08 0d 48 00 32 00 00 0e 74 15 // Set the voltage thresholds that control balancing.
<- a5 01 1f 08 01 10 00 00 75 30 01 f4 78
-> a5 40 12 08 00 00 00 00 00 00 00 00 ff
<- a5 01 12 08 01 10 00 00 75 30 01 f4 6b
-> a5 40 20 08 07 d0 00 64 00 00 00 00 48 // Set the short-circuit shutdown threshold and the current sampling resolution.
<- a5 01 20 08 01 10 00 00 75 30 01 f4 79
-> a5 40 11 08 01 0e 00 00 01 00 00 00 0e // Set the "Number of acquisition board", "Cell counts" and "Temp Sensor counts" ???
<- a5 01 11 08 01 10 00 00 75 30 01 f4 6a
-> a5 40 13 08 01 02 15 03 06 ff ff 00 1f // Set "Battery operation mode" / "Production Date" / Battery Type" and "Automatic sleep time" ???
<- a5 01 13 08 01 10 00 00 75 30 01 f4 6c
-> a5 40 14 08 32 30 32 30 30 33 30 36 8e // ??? Set the "Firmware index number"
<- a5 01 14 08 01 10 00 00 75 30 01 f4 6d
-> a5 40 17 08 01 32 30 32 30 30 33 30 5c // ??? Set the "Battery code"
-> a5 40 17 08 02 36 20 20 20 20 20 20 fc
-> a5 40 17 08 03 20 20 20 20 20 20 20 e7
-> a5 40 17 08 04 20 20 20 20 20 20 20 e8
-> a5 40 17 08 05 20 20 20 20 20 20 20 e9
<- a5 01 17 08 01 10 00 00 75 30 01 f4 70
-> a5 40 19 08 10 36 10 04 0a f0 0b b8 1d // Set the Level 1 and 2 alarm thresholds for high and low cell voltages
<- a5 01 19 08 01 10 00 00 75 30 01 f4 72
-> a5 40 1a 08 02 44 02 3e 01 88 01 b2 c9 // Set the Level 1 and 2 alarm thresholds for high and low voltages for the pack as a whole
<- a5 01 1a 08 01 10 00 00 75 30 01 f4 73
-> a5 40 1b 08 6b d0 6f 54 7e 90 78 1e aa // Set the Level 1 and 2 alarm thresholds for charge and discharge current for the pack.
<- a5 01 1b 08 01 10 00 00 75 30 01 f4 74
-> a5 40 1e 08 01 f4 00 c8 0a 0f 78 1e 77 // Set the Level 1 and 2 alarm thresholds for allowable difference in cell voltage and temperature sensor readings
<- a5 01 1e 08 01 10 00 00 75 30 01 f4 77
-> a5 40 1d 08 03 e8 03 fc 00 c8 00 64 20
<- a5 01 1d 08 01 10 00 00 75 30 01 f4 76
-> a5 40 1c 08 5f 69 05 00 69 6e 05 00 b2
<- a5 01 1c 08 01 10 00 00 75 30 01 f4 75
