That does sound like an issue. It very well could be damaged. I wonder if the bypass relay has seized.I've linked the whole issue to 1 of the inverters. It was running hotter than the rest during the cold night, taking 200w more than it is feeding, and producing a weird a high pitched noise.
I think it is damaged due to how bad the parallel system starts/stop (one inverter at a time, not all 3 simultaneously) so it ran all the load for a second before the other 2 kicked in to carry their parts.
I have around 50cm between each.What distance between the master and slaves where we talking about here?
I found a YouTube videon of a deye rebrand called LionEnergy. The inverter produced the same buzzing issue and it was diagnosed as bad relay.That does sound like an issue. It very well could be damaged. I wonder if the bypass relay has seized.
Just re solder a replacement onto the board.I found a YouTube videon of a deye rebrand called LionEnergy. The inverter produced the same buzzing issue and it was diagnosed as bad relay.
Now i wonder how can i repair it.
I'm now looking for repair shops in Lebanon. 2 of 3 inverters are now doing it, seems like the issue is propagating.Just re solder a replacement onto the board.
If you are comfortable doing it.
