OTRwSolar
- Apr 5, 2021
- 208
Trying to fully understand the difference between the two different model Victron Multiplus II 3000va inverter/chargers. Pricing appears similar for both.
Noticed the 2x120v model has an extra "L2" terminal for the AC in and both AC outs that the 1x120v model does not. I believe this "L2" terminal supports AC pass-thru for items that will/should not be powered by the inverter??
I also believe the 2x120v, not only supports standard 120v operation, but also supports 240v split-phase operation, along with 50a RV support, too.
In a nutshell, I get the impression the 2x120v model will do everything the 1x120v model will do and more. With pricing very similar, it would seem the 2x120v is the smarter choice if there's even a remote chance you may change applications in the future.
Thoughts? Opinions?
Thoughts? Opinions?
