chrisclifford
Hi all, I've installed a solar system in my van and so far it has been working well. I have a Victron charge controller and battery monitor, and a Renogy 200ah Lithium Iron Phosphate battery (I am aware that Renogy is not the most reputable manufacturer). I installed the system about 3 weeks ago, and the battery's BMS said it was at 95% charge after I charged it for the first time. I manually set the Victron battery monitor at 95% to sync the two. After using the system for a few weeks, the Victron monitor still says it's around 93% after some discharge and recharging. However, the BMS in the battery says it's only at 73% charge. No settings have been changed on the charge controller. Any idea what is causing this discrepancy? I assume that the BMS is more accurate? Any advice is appreciated. Thanks
