luisenriquereyes
CELL INFO
Nominal Voltage: 3.2 Volts
Battery Capacity: 138 Ah
Watt-hours: 0.4416 kWh
Dimensions: Length 960mm * Depth 14mm * Height 90mm ( Lenght 37.8 * Depth 0.55 * Height 3.54 inches )
Weight: 2.63 Kg ( 5.8 lbs )
Max continuous charge current: 1.5C
Max continuous discharge current: 1.5C
Working temperate charge: -10~+50C (14 to 122F)
Working temperate discharge: -20~+55C (-4 to 131F)
PACK INFO
Nominal Voltage: 51.2 Volts
Watt-hours: 7.066 kWh
Dimensions: Length 960mm * Depth 84mm * Height 270mm ( Lenght 37.8 * Depth 3.3 * Height 10.6 inches )
Weight: 42.08 Kg ( 93 lbs )
![1640454704887.png 1640454704887.png](https://diysolarforum.com/data/attachments/77/77111-8c92d77eb72cc3005da63f1707fda21b.jpg)
![1640454820118.png 1640454820118.png](https://diysolarforum.com/data/attachments/77/77112-7555677539abf7d7ed9d219704a2e426.jpg)
![1640454863181.png 1640454863181.png](https://diysolarforum.com/data/attachments/77/77113-52b1b4499f93c613c2ef8f278d13164b.jpg)
![1640454933475.png 1640454933475.png](https://diysolarforum.com/data/attachments/77/77114-bf272d275b88f20f9e9131db40369332.jpg)
![1640454972240.png 1640454972240.png](https://diysolarforum.com/data/attachments/77/77115-57e78af2c39f9080048bbe8184882e29.jpg)
Cost / Price
1 x 16S1P BYD Blade Battery Pack with screws and bus bars: $685
1 x BMS for 16S1P: $110
Shipping from ShenZhen China to Miami Florida: $425
Total: $1,220
What do you think?
MORE INFO:
The cells are from Shenzhen Zhongtong Battery Co., Ltd. on Alibaba:
https://vancely.manufacturer.globalsources.com/si/6008855331313/CompanyProfile.htm
After intial contact on Alibaba, they asked for my email and I get messages from the domain xuhotrong.com, from a jack at xuhotrong.com
Their listing for the BYD Blade cells:
BYD 3.2V 138AH deep cycle blade battery rechargeable lifepo4 lithium ion battery
Is this company legit?
What do you think of this battery pack?
More info on the BYD Blade Cells here: https://en.byd.com/news/byds-new-blade-battery-set-to-redefine-ev-safety-standards/
PACK INFO
Cost / Price
Total: $1,220
What do you think?
MORE INFO:
