Johnmahon
What's Your State of Charge?
- Nov 2, 2019
- 111
I’m doing the same thing in Arizona where we have 320 days of sunshine. I have a 10x12 shed with r19 and r30 rating insulation to help with the 115 degree summers. I’ll have a window mounted AC unit to help in the dead of summer.
Here are my questions for the group. I’ll be installing two Panasonic 335 watt HIT panels (specs here: https://a1solarstore.com/panasonic-hit-335w-solar-panel.html) and I want to do a 24 volt system using two battleborn 100ah lithium batteries in series. With this, configuration, what charge controller and inverter should I use?
I’d like to use Victron 100-30 charge controller or this all in one MPP system found on Will’s site: https://www.mobile-solarpower.com/all-in-one-solar-power-packages1.html
What is the advice of the group?
Thanks!
John
Thanks!
John
