strikehammer
I have some 13 year old panels that have been exposed to the sun but not connected for several years. Would they be the same as those in constant use? How about if they were stored out of the sun but still the same age?
I have wondered this same question and look forward to the replies for it.I have some 13 year old panels that have been exposed to the sun but not connected for several years. Would they be the same as those in constant use? How about if they were stored out of the sun but still the same age?
So disconnecting in sunlight is terrible? Or is it just frowned upon? How many disconnects matter? Cumulative of course. But is it .0015% per disconnect or .1%?disconnected in sunlight
I mean remaining disconnected in sunlight, or not operating in sunlight.So disconnecting in sunlight is terrible? Or is it just frowned upon? How many disconnects matter? Cumulative of course. But is it .0015% per disconnect or .1%?
Ok, good to know. sorry for reading that wrong.Panels open circuit in sunlight degrade faster than when operating for academic reasons beyond me. Probably the higher voltage. The electrons get nervous and fighty.
So if not in use, it would be better to short them out than leave the connectors hanging?I mean remaining disconnected in sunlight, or not operating in sunlight.
Actively disconnecting under load in sunlight is bad for a different reason, arcing on the connector.
This is exactly what I've seen debates about. My conclusion is that the difference is too small and the ramifications of shorting are too poorly understood. So I don't do it. But it has been proposed.So if not in use, it would be better to short them out than leave the connectors hanging?
I believe it requires 60a."48V" isn't a thing for PV panels. What does the label on the PV panels actually say?
Link to data sheet and manual for inverter?
Does it say what input voltage is required to charge 48V battery? Typically some amount of voltage headroom is required.
