I am starting to test power tools, heaters with blowers, welding equipment on my inverter. It's on a 12v trailer. 300ah bat with a bms that allows 250a stable draw 600a I think inrush.
I was running a 1500w heater fan, some drills, etc. . I was drawing around 180a.
There's a mathematical formula for where current is drawn from - when you have two voltage sources, one being higher, more current gets drawn from the higher voltage source until voltage drops enough.
The Renogy bat charger was running at 14.2, my bat is at 13.3.
I saw the voltage drop on the renogy, bat light was flickering. Something clicked, hope it was a relay.
It's still fine and charging. But like, I don't think think the charger is designed to see inductive loads. Should I disconnect solar panels when drawing crazy amounts of current?
The Renogy 40A MPPT is realistically designed for a camper with maybe a cooler running, or a TV and laptop? Not saws, tig welders etc.
