I just picked up a new Sunbeam electric blanket to use on a camping trip. It’s works fine plugged into municipal power but won’t run on the Ecoflow Delta 2.
It draws about 100 watts plugged into the wall. When it’s plugged into the Ecoflow, it pulls a hundred watts for about a second, then goes to zero. Every minute or two, it’ll briefly pull 100 watts then go immediately to zero again. I tried it on the Ecoflow river with the same result.
I went through the manual and noticed it says not to use with a generator or inverter. Any idea why this is the case? And if it’s limited to sunbeam or a problem with how electric blankets work in general?
Thanks,
— DY
Thanks,
— DY
