Hello! Excuse me for my language, English is not my native one.
I received my SHP combo (with 13 relays), hooked everything up end encountered an error: 5 out of 10 relays were red,
in application I found an error like "relay is not plugged in" for all of those 5 red relays.
Because of complicated logistics and the fact that everything was connected and mounted
I was not eager to unmount it and send back to seller.
I started to google for this error and found this forum and a few quite similar posts over the internet.
While reading carefully I realized that there is a chance that the problem is purely mechanical,
like relay circuit is broken at some place.
Initially I played with replacing relays and found that their position affects somehow if it's working or not.
Then I decided to disassemble SHP and examine its motherboard and contact plates - everything looked good.
Then I started to tilt relays and found out that tilting it to the right makes almost all of them flashing red,
and in opposite, to the left - everything comes to normal, they began to work.
It became obvious to me that the electrical contact responsible for determining if relay is plugged
in is located on the left side of relay's contacts plate.
I fully inserted one of the relays and took a mirror to look underneath how deeply it is inserted and observed
that it has some remaining height on contacts plate, also I noticed that there are scratches on all contacts
except the really short one.
I decided to check my assumption on one of the relays that was giving me the error.
I took the file (rasp) and removed about 1 mm of contacts plate bottom part.
It took me a few minutes. Then I inserted it - and voila, issue was gone, everything was working perfectly!
I "fixed" all relays this way and it worked for all of them.
Now my SHP is working for the fourth day in a row without a single issue.
If you are brave enough: consider my approach, of course all responsibility is yours
Result (green light - is a circuit feed from the battery):
P.S. a small update on this post, I bought one new relay and it definitely differs from what came in SHP combo
