I am attempting to charge my Power Pro battery using a generator, but cannot get the Gen input on my 18kPV to send power to the battery. Connecting the gen to the Grid terminals and selecting micro-grid in the menu does work, I ran it up to 100amps charge current and charged from 55% to 72%. The 18kPV is partially setup, no PV, grid or load wiring is connected. Generator is a Powermate 9400E, a Generac rebrand. 7500 watts/9400 startup.
Until the inverter attempts to charge the battery, I see 243-244 volts, about 64hz and 80-90 watts coming in from the generator, it will power an unloaded inverter. When it tries to send power to the battery, I hear the relay click and a brief strain on the generator, about 400-800 watts going to the battery, then a second later it unloads with a relay click, normal light goes out and warning light comes on. It will try again every minute or so. Not sure if I missed a setting, generator setup options are pretty sparse. Smart load is not selected. Firmware 1312, LCD version 12.
Any ideas where to go from here?
