nEVER_confused
Eg4 18kvp inverter. firmware fully updated 1-16-24. Eg4 LL 48v batteries. firmware updated as of 1-13-24. finally got the batteries to get recognized by the inverter (not simple plug and play as advertised) after setting the batteries to rs485 p03Lux. inverter set to battery brand Lithium 6.-Found on these forums -THANK YOU ALL! charging -no problem SOC is accurate, batteries top off with solar or grid. i am not set to set to export to grid yet so those settings are off.
now the problem. when it gets dark and the panels are done producing i expect the batteries to kick in and provide power, supplemented by grid if necessary. the batteries won't discharge. at all. Kill the grid input - all goes dark. batteries don't kick on.
The odd part is that i am using the same settings as a friend with the exact same setup, except he has Eg4 lifepower batteries, and his works fine.
I have even tried Forced Discharge and that is doing nothing. Discharge settings attached.
