natehawkv8
- Aug 18, 2022
- 13
I have a SRNE hybrid inverter split phase with battery connection, AC in, AC out and PV in. In SBU mode and even with inverter switched off im getting solar panel DC voltage on AC outputs if I put my volt meter on AC out ground and L1 (or L2). If I switch off PV breaker the DC voltage no longer shows on AC output (this seems to prove unwanted DC voltage is in fact coming from PV). Anyone ever experience this? Also when in SBU, AC output ground to L1 (or 2) only shows 50v when it should be 120v. When in UTI everything works fine.
