I have a 4s LFP in an RV. Looking for a BMS with separate charging input and low-temperature protection.
Any Suggestions?
[Here is my long winded legacy post:]
I have a DIY LFP battery made of A123 cells and a 100w solar panel in a Westie camper.
I'm concerned when it gets close to freezing, the battery might be damaged.
I do have a 12v resistance heating pad salvaged from a seat heater, and maybe could fashion a simple thermostat to power up the heater when the temperature drops.
One failsafe might be to power the heater directly from the solar using a thermostat circuit, thus not pulling down the battery.
Already sounding a bit complex and prone to failure.
Starting to think it's simpler to have an automatic thermal cutoff to the solar circuit (and alternator feed)
and maybe a manual switch to the heater pad so I could warm up the battery manually if necessary
What are the best approaches to automatic cutoff?
I don't currently have a BMS since all my loads are running through a Victron solar controller load output (and inverter with it's own low-cutoff protection)
So maybe add a BMS with separate charging input. Bonus if the BMS has temperature sensing cutoff, too!
System maximum draw is probably around 50A (but realistically closer to 30A)
Suggestions for a 4s LFP thermal sensing / protected separate charging port, BMS?
Thoughts?
Any Suggestions?
Thoughts?
