I've made a decision, going to have the JC Refrigeration upgrade kit installed on my existing absorption fridge. While shutting it off everyday has generally been working good, I've developed another issue where relighting hasn't always worked.
The choices are
- replacement absorption unit
Cost is moderate, but I'm done with the propane absorption fridge. There are way too many problems with the current designs and early failures
- RV specific 12v fridge
very expensive, and there a lot of negative reviews with infant mortality
- residential fridge
Cheapest solution, but will require detail fitting work, runs on 120v, and the decor will no longer match
- compressor upgrade to my existing fridge
Moderate cost, can get 12v system. Cooling not quite as good as RV specific or residential, but much improved over the absorption cooling. Get to keep the decor.
12v will run off my battery bank. I shouldn't have any major issues, but I won't be getting over 5 days off my battery bank with little to no solar collection
