KBWaldron
I'm planning my Solar Array wiring. I'm at the stage where I am identifying parts for purchase. My array will be a 2s4p, so 4 pairs of lines coming into the combiner box. I want to put fuses on each positive line before attaching them to the bus bar. I'll need a 20 amp, 60volt fuse holder according to the specs of the panels. Two issues:
- 60 volt is hard to find and expensive. Do I need to worry about the voltage that much. Would a 24 volt fuse holder work?
- I'm going to be putting about 16 amps maximum through each line. The panel wires are AWG 10 which is pretty much par for the course I believe. However the fuse holders I am finding have higher gauge wire, AWG 14. Do I need to worry about those short wires heating up in the combiner box, or voltage drop?
