I've just looked at mine, it does have the option for the alarm, I'm just looking through my instruction book to see if there's is a reason it would not show. I'll get back to you.
Hoi Peter,
Ik heb net naar de mijne gekeken, het heeft de optie voor het alarm, ik kijk gewoon in mijn instructieboek om te zien of er een reden is die het niet zou laten zien. Ik kom bij je terug.
I have just downloaded an instruction book and the alarm parameter is missing. So it looks like some versions have this option and some don't.
Ik heb zojuist een instructieboek gedownload en de alarmparameter ontbreekt. Het lijkt er dus op dat sommige versies deze optie hebben en sommige niet.
That is the same firmware as mine, and I do not have the alarm param.
If someone who has the alarm param could check their version, that may be a clue....
This one from Jhonny has a different Firmware version, Notwithstanding the box of my Witte MT 50 as well as the manual of it that there should be an acoustic noise alarm present?
It is also stated on my packaging box that it should be present!
I have just written the seller back see print screen below.
Furthermore, I will leave it at that and not trade it because I have the latest version AN Series from Tracer and also the latest model of the MT 50 with the latest firmware
