cristipurdel
- Nov 30, 2019
- 13
I am looking for a Grid Tie Inverter Load Controllable, preferably a branded one and not a cheap one, which should have a battery mode management for LiFePO4 (e.g. 24V) to reduce my baseload. The post is linked to battery system with power output control for maximizing self consumption bypassing net metering.
My scenario would be:
300W peak solar, so around 1.44kWh peak solar energy daily
60W baseload ( = 1440Wh / 24h)
The GTI should be able to perform the following:
Case 1 : 300W solar = 60W baseload + 240W battery
Case 2 : 40W solar = 60W baseload - 20W battery (e.g. until SoC = 70%, disconnect afterwards)
Case 3 : 0W solar = 60W baseload - 60W battery (e.g. until SoC = 70%, disconnect afterwards)
The main goals would be to:
eliminate the base load completely
not use net metering
not mess with main cables nor control power (e.g. solar legion type)
conserve battery life by having high SoC
