Is this normal that my inverter is discharging batteries every day around sunset or sunrise?
The settings 14. Charger source priority:To configure charger source priority: is set to Solar Only (CSO) or Solar Energy or utility (SNU),
but every day I see on the graph discharging like below.
There is not a lot of sun these days in winter Poland hence my set of batteries is hitting 10% even they charged next day and this is causing alarm,
they barely charging each day form solar so I do support them from grid,
however shouldn't be the case in this settings that the batteries are used to feed the home only if settings
1. Output source priority: To configure load power source priority is SOL or SBU?
My settings in 1. is SUB (Battery provides power to the loads only when solar energy is not sufficient and there is no utility.)
Do you experience similar behavior?
My idea was to stay with full batteries and use them to feed home only in UPS mode when there is no grid available.
Please advise
Please advise
