Can you explain more, My installer put My Eastron 230 V2 (in mini CU) after 100A breaker and just before my solar pv is one one 20A MCB and AC Inverter/Battery on another 16A MCB, in the mini CU with tails from the Henley block, seperate from Main CU which also has seperate tails from Henley block....
where should the Eastron 230 be connected?
Have taken the mini CU cover off to see what is connected....
Eastron Meter has Pins 5 white/orange 485A and 6 brown 485B connected by RJ45 cable but hanging loose (The Solax X1 AC3.6 manual states for Meter connection to Eastron SDM 230 is Pins 7 white/orange and 8 Brown of RJ45 pinout. I have a feeling it is not connected up correctly plus no RJ45 cable connected to inverter connector, hanging loose., Inverter connector is used by CT ethernet RJ45 on Grid live.
Just found CT from Inverter Solax X1 AC 3.6kw to Grid Live cable (after DNO Meter) but before the Henley Block which is giving my readings.... which is like 100w above as in the thread... nearly 2kw daily for 24 hr period
How should the Eastron V2 be wired up.....
https://www.jwsmartmeters.co.uk/wp-content/uploads/2018/02/Eastron-SDM230-Modbus-v2_User-Manual.pdf so I can check why it is not being used... the box the Eastron meter v2 came in states for Solax and Growatt inverters...
This has all happened after my solax AC inverter and Master and slave 11.6kw batteries were installed last month. Electric has been halved
and cost and very happy, but came along this thread and started to investigate....
Any help is greatly appreciated.
