Say I have a Victron Multiplus 12/2000 with a max continuous of 1600w and a Victron pheonix 12/1200 with a max continuous of 1000w, both connected to the same battery bank.
Could I connect the pheonix 120v AC output to the multiplus AC in to basically trick the multiplus into thinking the pheonix inverter was grid power or generator power. Then limit the AC in to about 8amps to avoid overloading the pheonix.
This would temporarily allow for a max continuous of about 2600w out of the multiplus using the assisting feature.
Would this work? I understand there would probably be some losses but ultimately allow me to basically parallel both inverters for a higher output.
