Luanne
I got a bluetti ac300 with b3000 and 420 watt panel. When I try to charge it up with my generator it won't charge...the fuel generator runs for hours n the bluetti isn't charging from it. I'm using a 10,000 watt generator to try to charge it. I live off grid with the bluetti as my power source as the fuel generator is too expensive to run even tho it's duel fuel. I have my 40 ft 50 amp (reduced to 30 amp) rv plugged into the bluetti and then use bluetti charging cord plugged into my fuel generator. Right now I'm using the solar panels cause it's sunny outside. The bluetti is out in the shed...should I bring it inside the RV....? It get cold in the shed....I don't know what to do...please help! Thank you! Luanne
