McDavid403
- Oct 16, 2021
- 24
Hi, I have the JBD Smart BMS 4S Lifepo4 200A BMS with Balancer. Model sp04s034 on my 4 cell 280Ah build.
Have been charging with solar sometimes with my generator. Things were working fine until now. Am seeing one of the cells (cell 4 in my setup) have big voltage drops when a large load is running. All 4 cells would be similar and then the 4th cell would drop suddenly, for a sec then go back to normal.
Corresponding with this is the lights will flicker and the inverter will trip with any load. 400w or higher and then everything would go back to normal after it trips. This repeats itself anytime there is a large load. I have the Renogy 2000w inverter.
Any ideas? Can anyone share BMS config setting if you have a similar setup? Should I update my firmware? I am thinking it’s in my BMS. When charging on solar, I see the same behaviour on that 4th cell. It would blip and spike in voltage and then drop down to match the other 4 cells. Not sure if I need to rebalance cells.
Am calling right now with no cell service but when I go to cell coverage am away from BMS but will try to take a pic of my settings and post next time I’m in cell coverage area.
Thanks in advance!
